Hi,
I want to know if it's possible to add subtitle effects in Adobe Premiere. Right now I subtitle episodes using SSA and that's pretty much for dialogue etc. I want to add some special text effects like words flying on screen and cool fades and someone told me that I could do it easier on Adobe Premiere. Also is there a way to do Karaoke on Adobe Premiere also? Basically I want to read up a guide unless someone wants to help explain it to me. I haven't used Adobe Premiere in my life so I'm quite new to it.
I also want to know if it's possible to encode movies to higher quality using Adobe Premiere rather than Virtualdub Mod. Like I have an mpeg-2 ripped from a DVD and I want to encode that to a wide screen high quality movie for televisions such as HDTV. Can anyone provide me some help? Thanks!
virtualdubmod doesnt encode to dvd ...
premiere can do what you want -- but that is a lot of text and scrolling to do for karaoke ..
you can re-encode a dvd to hdtv - yes .. BUT
1. how are you going to play it back ?
2. it prob. will look no better - maybe worse .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by BJ_M
And what I meant about HDTV was if I could make a movie on DVD into a widescreen avi with adobe premiere. Also is it possible to add an SSA file into adobe premiere so that when I encode the video I have an avi with hardsubs, while at the same time maybe put in special text effects for the credits? -
Hi dqtus,
what I meant was I would encode files from DVD to AVI with virtualdub mod and I wanted to know if adobe premiere could do a better job at that?
Hope that helps. Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Originally Posted by daamon
I actually dont like to use dvd2avi since that doesnt give me the quality I like so I just use virtualdub mod but someone mentioned that adobe premiere could work better that's why I'm trying to give that a go. Anyways I'll read over the link
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Adobe After Effects Questions
By HoosierGuy in forum EditingReplies: 25Last Post: 2nd May 2011, 21:12 -
Adobe Premiere Pro CS5 Editing Effects?
By Napy666 in forum EditingReplies: 1Last Post: 20th Aug 2010, 18:43 -
Render farm for Adobe After Effects and/or Premiere?
By Mylo in forum Video ConversionReplies: 1Last Post: 21st Feb 2009, 14:46 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17
