I have read that it is possible to enable the DV link to USB PC of my handycam to pass data IN and OUT (now it is enabled only to OUT). Someone knows how to di it? Thank in advance
On a lot of Sony DV and Digital 8 camcorders, you can enable the Firewire (i-Link) in using a widget, not the USB. On Digital 8 camcorders, the analogue in is enabled too. Go to http://www.dvstuff.co.uk/ and click on DV-in Enabler on the left hand side of the page. Looking at the list, the 103E doesn't appear. Are you sure this number is correct?
The reason why DV in is disabled on a lot of the lower spec European camcorders is down to the level of import duty. The import duty is set as a percentage of the cost price to the importer. That percentage is higher for a video recorder than for a camcorder. A camcorder with DV In enabled can be used as a video recorder so attracts the higher level of duty. As most people that buy a camcorder would never use the feature, it allows Sony Eurpe to keep the retail price lower by not giving a feature that most buyers wouldn't use anyway. -
Thank for your reply. The Sony model is DCR PC 103 E PAL but the strange thing is that I cannot find it also in driver update on Sony Web Site! May be this is the code used to sell the cam in Italy, and that abroad Italy the code is another one.
Sony Handycam DCR-HC53E -- help!
By Gew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jun 2010, 18:52 -
Sony DCR-PC108E Handycam
By ckbasak in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 13th Jan 2010, 13:57 -
Enabling LANC on new Sony Camcorders
By mofo22 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jul 2009, 10:31 -
Enabling V-Sync for old 2D Shooters in WinXP & Vista...
By retroborg in forum ComputerReplies: 2Last Post: 19th Apr 2009, 11:35 -
Sony DCR-TRV285E PAL - poor capture/playback under Linux
By glen.richards in forum LinuxReplies: 2Last Post: 23rd Jun 2007, 09:29
