I've just downloaded a couple of movies which are riff files( whatever the heck that is) Why don't folks just simply use divx or xvid to decode these things. Everything has to be so complicated. Is there a reason for this?
Anyway, I've seen a couple of threads about this but none answered what I want to know. How does one play a RIFF movie? I've checked to see what codecs is missing with Gspot but it tells me it's a mpeg file. So why doesn't it play?mmmmm.
I've waĆ*ted so long to download movies only to find its coded with codes Could someone please be so kind as to explain what Riff is and why it's used. And the most important of all how do I play them?
I just don't want to think all that time downloading was a waste of time. Thank you all.
Charles King
http://homebuiltstabilizers.com -
Assuming these are legally downloaded movies from a reputable site, there should be some sort of Help or FAQ to refer to. Otherwise, you're on your own...
http://ccrma.stanford.edu/courses/422/projects/WaveFormat/
http://www.music-center.com.br/spec_rif.htm
Good luck!
Best way to play Downloaded 3D Movies
By mafioso22 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Feb 2012, 13:22 -
What Program will convert both DVD and Downloaded Movies ?
By JMGrande in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2009, 16:46 -
Viewing downloaded movies
By orangekrush in forum Newbie / General discussionsReplies: 8Last Post: 16th Dec 2008, 04:10 -
How will HDCP affect downloaded movies?
By EatMoreChickens in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Jan 2008, 10:31 -
storeing my downloaded movies as data
By dgavob in forum Newbie / General discussionsReplies: 20Last Post: 10th Nov 2007, 01:21
