I've captured and converted the first part of Steambath. I captured 640x480 as that was the best VirtualDub offered, and now as I convert with TMPG SVCD wants 480x480 which is not possible to keep the proper aspect ratio. What do I need to do? I've burned it anyway and it plays perfectly but I'm not sure of the compatibilty accross Stand-Alones.
Hi.
You can resize your captured video by using the resize filters in VDub and frameserving to tmpgenc.
Or you can use VDub to capture in 480x480 (go to "Video/Set Custom Format" or press shift-F.
I capture a lot from VHS. If thatīs your case, I recommend capturing in 480x480 and then processing with CinemaCraft Encoder. Actually, I would recommend CCE over tmpgenc anyway, as it is much faster and produces (for me) better results in SVCD.
rgds
EBaldino -
I will definately try this now, as I've (until now) haven't been able to figure out how to get VDub to capture a custom format.
I tried CCE, but didn't have/don't have the program, or FAQ to lead me to the program to join them back again.
Can you point me in the right direction? You can E-Mail direct if you wish.
problem on captured VHS frames
By stefangs in forum Capturing and VCRReplies: 13Last Post: 5th Mar 2012, 02:38 -
640x480 VHS capture looks stretched on 50+ inch HDTV
By jrru2 in forum Capturing and VCRReplies: 11Last Post: 4th Nov 2011, 22:53 -
Should I use 640x480 or 320x480 with cubic for VHS capture
By groove365 in forum Capturing and VCRReplies: 4Last Post: 1st Sep 2010, 02:23 -
Captured S-VHS format
By Rinsin in forum Capturing and VCRReplies: 24Last Post: 28th May 2009, 13:05 -
VHS to DVD resize 640x480 or 720x480
By opti280 in forum Authoring (DVD)Replies: 2Last Post: 26th Feb 2008, 19:43
