  1. I'm recording DVB-S with MyTheater in MPEG-2 format (the only one available by MyTheater) using the Elecard graph and that MPEG format can be played flawlessly with PowerDVD. I dont see any artifact or framefreeze. When i run it through VirtualDubMod to check for errors i get nothing. No errors.
    Now to be able to place this on a DVD to watch it on my Large HDTV i need to demux it to process it. When i try to demux it with either PVAInstrumento or ProjectX (PVAInstrumento does the better job out of the 2 IMO) I loose a large amount of frames which causes my video to skip.
    Why would I loose frames if my source seems intact?
    Oh, and on another note, my Quality signal meter is around 90-95% and my level around 70%.
    Can someone explain what the Quality and Level actually indicate? Seems that the Quality is the same as the signal meter on my receiver...but the level hardly changes.
    Need Help! :S
    Demux with TMPGENC "MPEG TOOLS"
  3. i'll try that as soon as i get home from work and post the results
    Thanks,
