HI! I was wondering if there was ANY way to get this stupid card to work in Windows 2000. The small amount of support on pinnacles website suggest that support is coming in DVR v2.6 - anyone help!??
If the card is Conexant chipset based, try this Universal BT8xx WDM driver:
- Download it from http://prdownloads.sourceforge.net/btwincap/btwdmdrvinstaller4.6.0.zip
NOTE: You can also search for "BT848" in http://sourcefourge.net if you want ot seek for newer releases.
- Extract it anywhere and run the EXE file. Don't forget to read the README text, because it has lots of useful info.
- Then when using VirtualDub, you must turn "Preview" mode on, because "Overlay" mode of HiRes frames is not suported by hardware. So it's possible, like in AT AIW to capture both fields of the frame.
NOTE: This driver is a God's Gift and far the best one I've tested. You can even turn FM tuning on using non-FM cards.
Avid Studio vs. Sony Vegas Pro/Studio
By HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 21:06 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 16:14 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 19:53 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 23:48
