Results 1 to 27 of 27
  1. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    It gets as far as "....windows is starting up) and then just hangs.
    The mouse moves around but no matter how long I leave the frigger it won't start.
    It was fine when I left this morning and my wife closed it down after my capture had finished, and although I'm sure it has no bearing my wife unplugged the scanner from an extension lead and used the extension downstairs (a co-incidence, I'm sure).
    I've tried booting in safe mode but still get the same hang "....windows is starting up".
    Anyone any idea's?
    Thanks,
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Do you have an old DOS floppy you can boot from that has scandisk on it?
    Edit: That won't work with NTFS. Never mind.
    Maybe boot from the Windows CD and let it reinstall over itself, saving your apps and settings?
  3. Lost Will Hay's Avatar
    Oct 2002
    Hey
    I've tried this last time I had a problem and seem to remember it warning me I'd lose some of my shit.
    Really pissed off, I purposely left my video editing machine free of any web access so I wouldn't suffer any virus or worm attacks, I wanted it perfectly clean, basic system and minimal software for capture and editing and this ******* happens
    Will
  4. Banned
    Sep 2004
    Inner Circle of Thought
    The repair option will do the same thing.
    You will need to reinstall your programs though using either option.
  5. Lost Will Hay's Avatar
    Oct 2002
    ..and what about any captures I have on drive, or any personal files?
    I have some mpegs I created this weekend ready for burning.
    I can't risk losing those, they took too long.
    Will
  6. Banned
    Sep 2004
    You will keep the data unless you format.
    However, your programs would need to be reinstalled.
  7. Originally Posted by Will Hay
    Will
    Hopefully your drive was partitioned so that you will only have to format/reinstall on your C drive....
    I recommend when putting a pc together to always ensure I have a partion strictly for data (D: or similar) so I don't have to worry (unless the MBR or something like that gets screwed) as data is most always safe...
    Believe me, I feel for ya'
    Peace,
    makntraks
    In the theater of the mind...
    It's always good to know where the exits are...
  8. Lost Will Hay's Avatar
    Oct 2002
    Okay, I'll try tonight and report back, bastard thing
    I did try create a seperate partition makntraks (when I first installed everything) but ran into problems and gave up.
    If I have to reformat I'll try again.
    Thanks to all,
    Will
  9. Banned
    Sep 2004
    You can reinstall without formatting.
    Aug 2003
    NE Ohio
    Peace,
    makntraks
    My setup:
    40 gig primary - OS and Programs
    160 gig secondary - Data and Ghost image of OS drive
    You get screwed once and you will learn to sperate your data and back it up ... everyone learns the hard way!
    BTW Will Hay:
    You could get a hold of another hard drive(don't bother with a huge drive cause you will not use it for data) and install it as you primary master. Do a fresh install of Windows then install your "old" HD as your secondary. Now you have a OS drive and a... messy... data drive. back up your data then format your data drive... re-install data from backups! Ghost your OS to the data drive.
    Good luck
    JSB
  11. Banned
    Sep 2004
    You do not need the OS on your data drive.
    If he is going to use 2 drives, then keep the OS on the OS drive.
  12. Member Ziffelpig's Avatar
    May 2003
    Soviet Canuckistan
    Use the safe mode command prompt or change your boot order in the bios to boot from your XP CD and use the built in restore command.
    http://support.microsoft.com/default.aspx?kbid=304449
    The only other option is to install over XP without formatting, you will have to install most apps and games but will not lose any data.
    Just shut up and listen dumbass
  13. Banned
    Sep 2004
    Or you could try instead of using safe mode, choose last known working configuration upon bootup and spare yourself the hassle of reinstalling/repairing.
  14. Originally Posted by bazooka
    IME, after a severe problem just as what Will is experiencing, I think best to reformat to ensure that the system install process starts from scratch. I've never been comfortable with a rebuild or even using the recovery console. Without a format/reinstall, there is ALWAYS junk left behind that could interfere with the rebuild....
    Wipe the slate clean I say!
    makntraks
  15. Lost Will Hay's Avatar
    Oct 2002
    ....as I mentioned it still hangs in safe mode, and it still hangs when I try "last known config".
    I'm thinking it's (the problem) hardware based, I'll play tonight and report back.
    I can't format, I'll lose the family mpegs I've edited and created this weekend.
    Will
  16. I would recommend taking a cricket bat to the bloody thing.
    Will,
    If you have a spare hard drive, I would take your current drive out and set it aside. Try loading Windows on the spare drive first. That will likely tell you if you're dealing with hardware or not. If it loads Windows, you can work from that point by installing your 'data' drive as a slave, and see if it can read that one as a non-bootable drive.
    It doesn't sound like a hardware failure to me...
  17. Whilst I am unsure as to whether this is me speaking or whisky, could you not try booting from Linux and copying the files across, then backing them up to CD or DVD, or even a UNIX partition on the same drive?
    https://www.videohelp.com/forum/viewtopic.php?t=237206
    This will also tell you if you have a hardware problem, or whether it is Windows having a fit.
    Indo's suggestion seems to be a lot more sensible to me. I have found both Knoppix and Mandrake capable of copying from a Windows partition and backing up data for me - this has saved my neck before...
    Anyway, best of luck!
    Cobra
  18. Lost Will Hay's Avatar
    Oct 2002
    Four attempts to boot last night, all without success.
    Re-installed windows with some trouble and a reset proved the same; a 'freeze'.
    Removed promise controller card, all CD/DVD drives and rebooted, another freeze.
    Another reset, booted fine.
    Backed all my data to DVD's, connected all drives/cd-rom drives etc, been fine since.
    ******* thing
    I have no idea.
    Does the CD-based OS see files on an NTFS drive, and will I be able to see my two 160gb HDD's connected to my promise controller card, when the drivers are installed within Windows X?
    I don't have a spare drive Indo, I'd have done this first
    I have a 30gb IBM that I used to use for this purpose but this died.
    Originally Posted by maknarrrtracks
    .....I think best to reformat.......Without a format/reinstall, there is ALWAYS junk left behind that could interfere with the rebuild....
    Windows media player will play avi's, but after the repair it won't play mpegs
    Will
  19. Originally Posted by Will Hay
    Will
    Is it a codec issue?
    Do mpegs play with this Media Player Classic?
    It's always a pain in th ass trying to get things back in proper order...
    Glad to help if I can,
    makntraks
  20. Lost Will Hay's Avatar
    Oct 2002
    I'll post the error messages in a day or two, but if I remember correctly the report is that a couple of dll files are missing.
    Bastard thing
    Will
  21. Banned
    Sep 2004
    How old is your motherboard?
    The bios may need flashing.
  22. Not if it was working before the reinstall.
  23. I think you should just make your wife BUY you a NEW PC...
    makntraks
  24. Lost Will Hay's Avatar
    Oct 2002
    The clock is never ******* right, no matter how many times I change it.
    Time for a new CMOS battery?
    Will
  25. Lost Will Hay's Avatar
    Oct 2002
    Originally Posted by Craig Tucker
    Sounds like
    Go on....
    Sounds like what?
    Will
  26. Member
    Mar 2004
    soddy-daisy
    i just went through the same thing. turned out the power supply was failing. it would power up but apparently not enough to drive the machine. by the time i figured it out i lost my windows and apps trying to fix windows. ended up re-formatting. it was time anyway. good luck.
