I used nero express 6 to burn a dvd-rw and the picture is great but no sound. I put all the VOB and IFO files in the VIDEO_TS folder. Does anything go in the AUDIO_TS folder? What am I missing here?
Nothing goes into the AUDIO_TS folder (usually). The problem seems to be not with NERO but with how you created your DVD folder files. Maybe you disabled all the audio streams. It would be easier if you stated what program you used.Originally Posted by wolfeman00
How do you disable/enable audio streams? The program I used was Nero. I went to DVD Video and placed all the files into VIDEO_TS.
But how did you obtain/create the various files that make up the DVD.Originally Posted by wolfeman00
Did you make this yourself from downloaded or home video. If so, what encoder did you use, what settings, what authoring app etc.
Does it play on the PC with or without sound or is the problem only on your standalone player?
Help us to help you.
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
