file properties:
MPEG Layer-3,128 kBit/s, 48,000 Hz, Stereo
640 x 272, 24 Bits, 153449 Frames, 23.976 Frames/Sec, 94 KB/Sec, DIVXMPG4 V3
i converted from divx to mpeg2 using TMPGEnc beta 12e+
then cut it using the BBMPEG ,but its got good sound(insync)and sharp picture but its jerky ,so i presume i used the wrong settings some where.
This 23.976 Frames/Sec seems to throw me off anyone tell tell me the method they use(templates,etc)
cheers
Try playing the svcd in a standalone player - many of my "jerky" svcds play great on my dvd player, but like Sh*t on my computer
Do you create PAL (S)VCD's by any chance? If so try the method I described here:
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=49346&forum=3
It takes more time to do the conversion because there are extra steps involved. But I've created a number of smooth running VCD's this way.
Hope this helps,
Willem
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 11:57 -
Stop DivX From Opening XviD
By DarrellS in forum Software PlayingReplies: 6Last Post: 23rd Mar 2008, 02:44 -
Is there a jerkiness (motion detection?) setting in CCE?
By robrosen in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 17:42 -
Bad NTSC to PAL converstion - jerkiness. How to fix?
By PTRACER in forum Video ConversionReplies: 34Last Post: 11th Sep 2007, 18:00 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34
