How can I install a codec for YUY2 and or UYVY avi files onto my pc so that software apps can play avi video files encoded using YUY2?
Your help will be appreciated.
wwjd
Direct x doesn't seem to support YU2Y. I want to use large uncompressed AVI files (YU2Y), edit them and then as a final step encode them into dvd. I have been told this is the best method to retain quality.
Unfortunaly quick time (I need a codac or something) will not support YU2Y and I need this support for soundsoap. I do not know how to get Adobe to write to a large uncompressed AVI files. I'm 65 and a real newby that need help with getting and installing a codac
Trying to convert AVI to MP4 (for iPad) -- Avidemux won't install
By monkeypack in forum Video ConversionReplies: 4Last Post: 28th Nov 2011, 08:18 -
Convert YUY2 to RGB
By jrivord in forum Video Streaming DownloadingReplies: 8Last Post: 19th Aug 2010, 10:21 -
Help with captured AVI: Vdub / HCenc / RGB / YUY2 / YV12
By Rinsin in forum Video ConversionReplies: 2Last Post: 13th May 2009, 18:57 -
YUY2 Codec for Quicktime?
By EZ-Fan in forum Software PlayingReplies: 1Last Post: 12th May 2009, 08:07 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43
