Page 2 of 2
FirstFirst 1 2
Results 31 to 43 of 43
  1. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by yoda313
    But wouldn't even a rotating ip address still have the same regional location? When I dial up at home won't it still have the same regional id (or even the same zip/starting point???)???
    I'd probably not discuss it until we get a mod sanction, only because it could be portayed as advocating a way to beat the system
    If in doubt, Google it.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Oh, well like I said I'm pretty ignorant as it comes to ip/routers/java stuff. I'm much more on the user end of it. I have little practical programming expierience.
    Kevin
  3. Banned
    Sep 2004
    Inner Circle of Thought
    Hello,
    Kevin
    Any time you have a question, pm me.
    I deal with networking on a daily basis. My major in college is network engineering and administration.
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Bazooka - Thanks! I also have a neighboor who has since moved to DC that's into network security. I bug him about the "background questions" too. You know, stuff you might have wondered about "why does this thing do that thing when I move this?" Anyway, I do have a lot of practical pc knowledge just not a whole lot of technical knowledge. Though I do know some.
    Kevin
  5. Originally Posted by jimmalenko
    Originally Posted by indolikaa
    That's the benefit of IP logging.
    To all:
    How does IP logging/matching go for dynamic IP addresses (dialup and some broadband) ? Useless ?
    If the mods think this should not be discussed in public, please PM.
    With a 'typical' IP address being xxx.xxx.yyy.yyy, the xxx numbers are not likely to change, even with dynamic addressing.
    Did I pass the test, bazooka?
  6. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Hello,
    Kevin
    Good idea. Limit it to PMs please. We don't want to give someone ideas and techniques
  7. I suppose that's a better answer than 'Try a Forum Search!'
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    too late, Cap
    I'll PM you my theory.
  9. Banned
    Sep 2004
    To all:
    Yep
    You have class A,B&C networks.
    Class A uses the first octet.
    Class B uses the first two octets
    Class C uses the first three octets.
    So you must determine whether you are using VLSM(variable length subnet masking or not.(VLSM is classless.)
    You might have for example 192.168.xxxx.xxxx, and you have to determine what the subnet is and the first usable ip address is.
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    It still surprises me how many companies still use that range for their internal networks...
    Not to mention home networks either
    All the IT techs must have remembered it from IP Adressing 101
  11. Banned
    Sep 2004
    192.168.......
    Most low end routers use the 192.168 range as well.
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    What are the "sacred" internal ranges again ?
    A - 10.x.x.x
    B - 172.16.x.x-172.31.x.x
    C - 192.168.0.x-192.168.255.x
    it's been a while but I've still got it ...
  13. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Hmm.... I've been wondering if Vader313 is open?????
    Kevin
    -- just kidding!--
