I hope you never need to use those.Originally Posted by northcat_8
Results 31 to 60 of 82
Actually, they have been fired in the vicinity of folks around my property at night time and once I shot the 30-30 into the rear end of a car...trying to steal tools out of my truck...yea...good idea
I live out in the sticks...no one just happens by my house. So if it is night time, our 4 little noise makers (the dogs) let me know, then I get up and "inspect" the surroundings.
If you are wanding around my house at night and get caught you'll hear "BANG BANG...who's out here?"
Thieves be warned, they are loaded, they are in my bedroom and the 45 is 12 inches from my head every night...break into someone elses house, you will not appreciate my hospitality. -
HOLY SHITE!!!!!!Originally Posted by jimmalenko
I've made a few potato guns out of PVC in my high school days, but I never even dreamed of a flame thrower! -
Very cool and very ballsy for a kid to build... smart kid... and it looked like such a nice and quiet culdesac.
Edit... I just noticed the PDF url .... Jim ... you are the ballsy kid eh? -
Originally Posted by bazooka
Yep, the pen.
You know what they say....
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Sounds like he does'ntOriginally Posted by Will Hay
Hush Craig, it must be a secret
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
The penis mightier than the sword?Originally Posted by Will HayNothing can stop me now, 'cause I don't care anymore.
I knew. I was just messing with will. That saying has been around well before I was ever thought of by my great great great great grandparents.Originally Posted by Craig Tucker
If u get a good woman, it is.Originally Posted by ViRaL1
Is the pen mightier than the gun? I'd like to know in case I ever get mugged.
Nothing can stop me now, 'cause I don't care anymore. -
Sounds like you have some intimacy issues you need to deal with....Originally Posted by ViRaL1
W.tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Still working on my one handed typing.
...applying lipstick with the other perhaps?
Jeesh, you women
<----Cerebral Assassin
or is that Cervical Assassin?Nothing can stop me now, 'cause I don't care anymore. -
I had poison ivy on the my brain once...the only way I could scratch it was to think about sand paper.
~Steven Wright -
Booo! Bad ..... That one should have been stamped "return to sander".Originally Posted by northcat_8
Here's my diagram I give to friends on how to make a nice potato or egg canon. Let me know if any of you want detailed instructions on how to build and what parts to use. Do not use the standard white PVC piping when making this. Some are a bit weak and may crack or explode. Use the black piping instead. I've never met anybody that has had one of these explode, but I don't ever want to hear of someone doing it the cheap and unsafe way. The sealant used should state it is able to withstand higher temperatures. It is not necessary for infrequent use, but continuous use or heavy repeating of firing will require something that can resist the heat better as you'll feel the chamber get warm after several firings. I'm sure it can be created out of metal piping instead, but it is heavy and get's hotter quicker and for longer periods of time. You will also want to find a heavy duty plastic dowel to make pins out of. It is not necessary, but it helps prevent the parts from separating if you do a shotty job of sealing the parts together. You may also want to make a plunger/ram to push the potato or slide into place for each firing.
I forgot to mention I have a tiny pipe assembly that I put an ingniter button in with 2 leads coming out to alligator clips. These clip onto the connection points. Now you have a trigger for your canon. Use solid large gauge wires and make sure the drilled hole is slightly smaller to give a tight fit. It is preferred to use quick steel to make sure the drill holes are completely sealed and keeps the leads from moving. THe holes should be about 3"+ apart. The internal contact should be bent toward each other leaving about 1/4-1/2 gap between them to allow a spark. If you want to know what propelants to use, PM me.
Damn ...Doramius. If I had known you when I was ten, you would have been my best friend
Cool 8) -
I was thinking either as an Albuquerque commuter vehicle, or something to roll up in if we ever have a Videohelp picnic
This is what I'm getting ready to drive to work in the future.
Office 2007 can't be uninstalled
By ukb007 in forum ComputerReplies: 3Last Post: 15th May 2011, 09:51 -
Office Depot CD-R bad or not?
By bevills1 in forum MediaReplies: 4Last Post: 10th Aug 2010, 12:59 -
The Office (UK)
By tgpo in forum Off topicReplies: 1Last Post: 6th Sep 2009, 22:10 -
Mass conversion of Office 2003 files to Office 2007?
By Xylob the Destroyer in forum ComputerReplies: 8Last Post: 17th Jun 2008, 00:06 -
Office XP Pro?
By videobread in forum ComputerReplies: 5Last Post: 8th Apr 2008, 13:11
