  1. I was wondering if anyone here could help me get rid of some spwyare/trojans/adware. I already have Spybot Resident, Ad-aware Personal, Advast Home Edition, Windows Startup Inspector, and ZoneAlarm. I have some knowledge with other techniques. I was wondering if you have any suggestions of other freeware programs or how to edit the registry to remove the spyware keys. Here is my exact problem. My home page is always changed to a pornographic site on startup. To me this sounds like background programs embedded in the registry. What do you think? Any registry help? Thanks.
  2. Banned
    Sep 2004
    Inner Circle of Thought
    Use hijackthis
    Apr 2004
    Hudson, Florida
    Bazooka Adware and Spyware Scanner 1.12 will fix your problems. You can get it at www.download.com
  4. Mod Neophyte redwudz's Avatar
    USA
    If you are using Spybot S&D, under 'Tools' there is a check to keep spyware from changing your IE homepage. But you probably want to get rid of the source program.
    If you find the name of the program you can delete the registry file. (After registry backup) regedit has a search feature that works well. Some of those nasty little programs change their name, so are a little hard to find.
    I have had good luck with the other tools in Spybot just trying to find oddball names that don't seem to fit it. (Use latest version) I would guess there is a registry entry that is the source of your problem.
  5. Member mikester's Avatar
    Aug 2004
    Richmond, VA
    A friend of mine hade the same browser hijack issue. Running the latest versions of Ad-Aware & Spybot did not fix the problem. We were able to remove it by using CWShredder (freeware). It immediately corrected the problem... You can download it from here:
    http://www.majorgeeks.com/download4086.html
  6. Member mastersmurfie's Avatar
    May 2003
    This
    Originally Posted by bazooka
    Use hijackthis
    and this
    worked for me several times on friends computers...
    just a thought
    mastersmurfie
