I have started to copy my Hi8 and DV tapes to dvd. Bought a Pinnacle Studio DV ver. 9 today. But I have found a problem. The movies looks nice and have good colors then playing in my camcorder - a Sony TRV 460 Digital8 - looking at the lcd. But then using Studio DV (and also WinDV) they have poor colors on my computer screen and seems to have lost contrast and are much darker. As newbe I hope someone can tell me what to do. As far I know are all settings correct (and I'm using firewire).
This article explains what you're running into (it's true of all DV):
http://www.signvideo.com/dv-black-levels-dvd-authoring-mpeg-2-part-1.htm
trock -
Lot's of variables here..... How the brightness and contrast is set on your TV, same thing for your monitor. Generally video will appear darker on a monitor. The software affects how it looks too, video made for TV doesn't look very good on a monitor. Your viewing software compensates for this. Burn a disc and see how it looks on a TV.
Even on TV the colors looks washed out, dark and liveless. Then showing the movies from camcorder everything looks fine on TV. Can it be any settings to do in my camcorder? Btw I use PAL.
A couple of things to try
1. Create a small clip and author it to DVD-RW. Play this on your TV. If the colours are OK, then it is your monitor's calibration throwing the colours off. Try to get your PC monitor and TV close enough together to be able to adjust your monitor to match, or else do it by eye.
2. If the colours are still washed out, then it something in the editing program or the encoding process affecting the clip. Look for filters you may have applied or anything else that could change the output.
3. Try a different editing program to see if this changes the output.Read my blog here.
Have had something similar happen if I had more than 1 video player/capture program open at 1 time.
I would have to capture the DV file and then close all programs and then reopen the DV file in say media player classic or an other video player.
After I did this, the computer would display the video with correct colors.
Not sure if the same problem, but just a suggestion.
Mini dv camcorder to computer
By ccastell88 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 21st Jul 2011, 07:37 -
Catpuring old NTSC tapes in Europe (b\w - color problem)
By Heartworm in forum Capturing and VCRReplies: 6Last Post: 13th May 2010, 21:25 -
Camcorder to Computer
By LittleDudeo in forum Newbie / General discussionsReplies: 4Last Post: 21st Jul 2008, 08:21 -
Poor DVD Quality - Camcorder to imovie08 to iDVD
By Karl K in forum MacReplies: 12Last Post: 28th Apr 2008, 22:53 -
Bluish tinted colors on standalone - OK on computer!
By mbmsv in forum DVD & Blu-ray PlayersReplies: 12Last Post: 24th Jul 2007, 13:20
