having read earlier posts regarding the burning of these files i'm still having trouble.
i've used nero,roxio,dvd decryptor and clone dvd.
all the films i've burnt have froze after about 5-10 mins into the films.
any ideas where i'm going wrong.
many thanks
newbie poster.
who did the encoding/authoring -- and how well
have you played the ISO on your PC using Daemon Tools?
Check it before you burn it, Pioneer,Decrypter to Ritek is a pretty stable combination...at least it has been for me. I would not burn with Nero. I know several people do, but it has never worked well for me. -
the encoding/authoring can be messed up - as i mentioned once before -- and it would still play on a pc ok , but not always in a stand alone..
playing on your pc though would show gross errors .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
If you use the latest nero click on burn image and then all files and then the image you wish to burn. This outta to the trick
Peace -
Originally Posted by chipchow
unless whomever made the image file goofed up in the encoding or authoring stage - first
he doesnt have a problem burning the image -- he has a problem playing them"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Converting ISO/IMG to AVI: How to choose the desire audio track ???
By htp367 in forum Video ConversionReplies: 3Last Post: 19th Jul 2009, 13:11 -
.iso, .img, .cue, etc. to DVD
By Xandal in forum ComputerReplies: 5Last Post: 26th Aug 2008, 12:52 -
Problem with .IMG/.ISO file
By macamba in forum Newbie / General discussionsReplies: 6Last Post: 6th Jul 2008, 04:57 -
IMG/ISO to DVD
By digitalred93 in forum Newbie / General discussionsReplies: 7Last Post: 28th Nov 2007, 23:59 -
Which is best to burn - img, iso or video_ts
By dynamique in forum Authoring (DVD)Replies: 10Last Post: 29th Sep 2007, 15:13
