Cool, thanks. Figured I'd have seen mention of it elsewhere (including here) by now.Originally Posted by AntnyMD
We sure do.People say the darndest things on the internet.![]()
Results 31 to 35 of 35
Originally Posted by alph
Brilliant - this is exactly what I want to do ... but I've been going round in circles for days trying to create a suitable mp2 file in ffmpeg. I either end up with an m2v file that won't open in Streamclip, or have a file ending in .ff which won't either. I've tried both ffmpeg and mpeg2enc engines.
I've got my head around your process but am stumped by this at the mo. is there any chance you could save the precets that you use and email them to me - that way I should be able to replicate what you've done. All the other parts seem to work ok. Would be grateful if you could help me out like this, or for any pointers as to what I may be doing wrong.
Cheers
Sion -
Originally Posted by Case
My goal here is to take one long mpg, or avi file and get it onto a DVDr with some chapters that can be jumped to. Ideally, i'd like to create a simple menu, too. Is there a tool that will relatively easily allow the addition of a menu either before or after reencoding to DVD compatible format? (but not starting with DV)
Am i correct in assuming that the only way to create a menu with Toast is to have what i want as chapters in separate files?
PS. I have all files spit out by ffmpegX: ac3, mpv, mpg, and the mpeg.DVD folder. -
You can use Sizzle (which allows to Author the DVD with menus&chapters) or Moviegate (only adding chapters). -
I tried using Sizzle (which seems awfully confusing) but even though my stream is mpg2 with ac3 sound prepared for DVD, the first thing it does is say it's demultiplexing it.
After ages, the progress bar has barely moved, but it's using >50% CPU. It doesn't take this long to demux!
I tried giving it the M2V and AC3 files separately, but it claims the AC3 file isn't 48 Khz, even though it is.
MPEG Streamclip Q
By cnelson87 in forum MacReplies: 12Last Post: 15th Apr 2012, 19:03 -
Help with MPEG Streamclip
By joelw135 in forum Video ConversionReplies: 10Last Post: 8th Jul 2010, 06:08 -
Can't Get Started with Streamclip
By cindyjk in forum MacReplies: 20Last Post: 22nd Feb 2010, 15:41 -
MPEG Streamclip help!
By squid3660 in forum Video ConversionReplies: 0Last Post: 5th Jul 2008, 22:56 -
By kita in forum MacReplies: 18Last Post: 28th May 2008, 02:14
