I am trying to crop spanish subtitles and am unable to because the cropping screen itself takes up more than my 17" monitor so I can't OK it. Is there anyway this cropping screen can be reduced? Tmpgenc is only if I want it to change it from avi to mpeg and I don't
Another thing is it absolutely essential to resize it once cropped as I am not going to convert it any further but just burn and view it on my divx player.
Originally Posted by lingoguysw5Hello.
I hit return like you said after cropping in orderto hide the subtitles. I found the resizing too complicated so didn't bother as I wouldn't know what to change them to. I then saved the video in direct stream under a new name and the subtitles are still there! Where could I be going wrong tommyknocker? Please let me know thanks
Well since it didn't work and am still left with the original file it still remains at 720 x 480. Again I don't know how to resize properly, but I doubt that should affect the cropping should it? According to the instructions for cropping there is supposed to be an O.K. button at the bottom of the screen which my cursor will not reach, but you said return would do the same thing and that hasn't seemed to work either. Where do I go from here? Should I full process it maybe?
I am putting it out as an avi tmpgenc file it hasn't finished yet but so far so good. I wasn't drawn towards tmpgenc at all, quite from it, in fact Virtualdub cropping had it worked would have been my favourable option as it would have been a look quicker to save as a direct stream. If I could only reduce Virtualdub's cropping screen and press OK as per instruction I am sure that too would have solved my problems, since pressing enter didn't seem to do the trick. Oh well
how we can implement "VirtualDub" or "FFmpeg" with my C# windows applicati
By dhemittal in forum ProgrammingReplies: 0Last Post: 8th Jun 2010, 07:17 -
U.K. to give new meaning to "Big Brother" is watching
By aedipuss in forum ComputerReplies: 11Last Post: 18th Oct 2008, 09:00 -
"The current DVD size is too big!"
By Charles in forum DVD RippingReplies: 6Last Post: 16th Sep 2007, 11:27 -
VCR Overscan Issues ("jittery" line at top of screen)
By jcm0320 in forum Capturing and VCRReplies: 14Last Post: 24th Aug 2007, 13:56 -
Nero Showtime shows black "screen" on secondary monitor.
By fk in forum Software PlayingReplies: 2Last Post: 12th Jul 2007, 15:06
