i just typed loads of stuff but because i had me dinner half way through i lost the lot , grrrr , so here goes again shortened kinda
avi , ac3 ntsc straight to mpeg2 , no i`m not asking how to author , just how the hell do i get the ac3 to synch with the m2v
i have demuxed with vdub and then in tmpgenc author selected both m2v and the demuxed file , that was out of synch , i tried to fix the demuxed file with filesplice ? , still out of synch
the original avi has a piece of animation at the start with no audio so i`m guessing thats where the 2 files are getting there different lengths , so how do i get rid of the animation so that the m2v and demuxed ac3 are the same length
i tried gol;dwave to stretch the audio to the m2v file length but that didnt work it was still out of synch
i`m out of ideas , please take pitty on me and shoot me or help me
cheers
foget it , i tried adding the difference between video and audio still no joy , told my m8 to do his own college work
deleted the damn thing , some ya win some ya loose -
OK try this:
Open the avi with vdub (or VdubMod) and go FILE > FILE INFORMATION, what does VD say about the lenght of the video file and the length of the audio file? Gspot should give similar info (use the latest version).
Also check the demuxed audio file is the correct length compared to the original (so open it/play it with a media player to check its length). -
the 2 files are of different length m8 , although they play on the pc synched
the reason is there is blank audio at the start of the file , but when demuxed it only takes the audio and not the blank piece
when re-joined to the m2v the audio gets added to early , throwing it out
tried the interleave settings and adding the difference but still no joy
i deleted the damn thing i spent all day sunday , demuxing , converting , reading , i had about 15 different audio files of various types in the end demuxed and none synched
i would like to know why i never got it to work , it was very annoying to have to give up but jeez the hrs spent trying wernt going down well with the mrs
i wrote the time lengths down
video 1:18.40.429
audio 1:18.37.063
i calculated a 3366 mil add on at the start of the audio file to make it fit the m2v but that didnt work , when played in tmpgenc auth it was still early , darn thing
[solved]What is the proper way to fix an ac3 synch issue in a h264 mkv file
By yoda313 in forum AudioReplies: 0Last Post: 16th Apr 2011, 09:46 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 21:53 -
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 11:17 -
converting mpeg2/ac3 and avi/ac3 to avi/lambmp3
By corumz in forum Video ConversionReplies: 2Last Post: 17th Sep 2007, 09:32 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 05:42
