I just bought a new hard drive and decided to do a new clean and fresh windows install. I have everything up and running again but now I'm having burning problems. For some reason during the burning process decrypter just stops. Sometimes it only burns a few minutes, sometimes it makes it halfway or more, only a couple have been successful. I have installed the adaptec ASPI version 4.71.2 and I've also installed the Intel Application Accelerator. I usually only use decypter to burn but I have also tried RecordNow DX with the same results. Does anyone know of anything else I should try to cure this. I don't think it's a media problem because I'm still using the stuff I was using before I got the new drive. Any ideas![]()
Perhaps you should try ASPI 4.60. Tried 4.71 some time ago, it caused weird burning failures on my comp, reverted to 4.60, all is well again. Good luck.
(Edit) : Install, reboot, run aspichk.exe to see if it took. Just in case someone out there has the same problem.
Pull! Bang! Darn!
Avi burning problems
By blitzen in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2011, 13:09 -
Dl burning problems
By calanda in forum DVD RippingReplies: 13Last Post: 14th Apr 2010, 00:25 -
TYG02 burning problems.
By videobread in forum MediaReplies: 2Last Post: 11th Oct 2009, 13:51 -
DVD burning problems
By Tbag in forum ComputerReplies: 13Last Post: 3rd Sep 2008, 16:55 -
DL problems after successful burning
By m-man in forum Authoring (DVD)Replies: 7Last Post: 9th Jul 2007, 20:53
