Hi all
I wold like to know where can I find Mpeg-2 videos with chroma subsapling 4:2:0, 4:2:2 and 4:4:4
thanks in advance
. Leo
Make them.
BJ_M is probably the most likely candidate to have anything shot 4:4:4 here. PM him.
MP@ML is only 4:2:0
HP@xx adds 4:2:2Want my help? Ask here! (not via PM!)
You are in Brazil, so it is difficult...
If you where in Europe, I would say: Buy a SkyStar 2 PCI card, install a 70cm dish and try to recieve the EBU transmissions from the Eutelsat W3A satellite, at 7 East. Those are PAL 4:2:2 ones...
Also, if you capture PAL through DV, it is 4:2:0, if that helps.
True PAL B/G, not PAL M/N. So you can encode this source using MP@ML profile for mpeg 2.La Linea by Osvaldo Cavandoli
4:2:2 is as best as your going to get with mpeg2 .. though i can certainly supply 16bit (per color) images at 4k (and 8k) in cin format (log) , though each frame is HUGE (50meg+ per frame) -- best quality you will ever see - though in cin format, you may not be able to view it ..
you can download a sample 2k res image here (12meg a frame)
http://www.kodak.com/US/en/motion/support/dlad/"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
thanks guys, but it didnt help so much...
if anyone finds this kind of files please let me know
Yes, but I belive the human eye almost cant notice. For compression, the chroma (color) is subsampled in 4:2:2 and 4:2:0 files, see the figure...is there a difference in colors/quality between these formats ?????
. Leo
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
