Hello,
After i rip some VOBs from DVDs via SmartRipper i find a problem:
When i play this VOBs with a DVD-Player like PowerDVD or RavientCineMaster, the language is always English. I can`t choose a different language. With some DVDs only comments were played and not the original DVD soundtrack.
Does anybody know a solution for this problem ?
thanks
postman
If you rip the dvd in movie mode, the vob files still contain all audio tracks, PowerDVD plays one of them.
Go to the stream processing tab and select only one language if you plan to play it with a software dvd player only.
https://www.videohelp.com/phpBB/viewtopic.php?topic=67016&forum=11 -
ya, playing the actual vobs directly with software DVD player is not indicative of the actual video/audio. For example, the vobs of widescreen movies i've ripped became stretched into fullscreen when i play on winDVD. sometimes, the director's commentary is played, or even french...but all that goes away once you encode it correctly.
rip the dvd in file mode & open the .ifo that belongs to the set of .vobs you want to play or the first .ifo for the dvd menu
DVD Ripping problem
By seajay in forum DVD RippingReplies: 23Last Post: 28th Dec 2012, 11:30 -
Problem ripping ET
By audax in forum DVD RippingReplies: 8Last Post: 27th May 2009, 19:19 -
DVD Ripping Problem
By Sscheme in forum DVD RippingReplies: 3Last Post: 4th Jan 2009, 10:08 -
CD Ripping Problem
By ThePMonkey in forum AudioReplies: 4Last Post: 25th Jun 2008, 07:47 -
Problem Ripping Movies
By WuPhilly in forum Newbie / General discussionsReplies: 1Last Post: 14th Jun 2008, 21:24
