I have some ownmade Mpeg2 files with several lines of permanent noise in them. The noise appears from line 97 to line 104.
Is there a way to clip those lines out of the result, so I have lines 1 to 96, and lines 105-480 combined to one new frame?
I know I can make them black, but that won'd look very nice in the endresult.
you can do this in most any editor.
put the clip on two tracks ...
crop the top on top track , crop the bottom on bottom track -- do a track motion on either the top or bottom to move them together .. Easier to do i suppose in premiere or vegas (as above).."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
What software do you have access to ? It might also be possible to rebuild the missing information as a blend from the lines above and below. Not the best solution, but you keep the aspect ratio correct and don't have a strange cut across the frame.
Read my blog here.
At the moment I have both Ulead Media Studio and Ulead Video Studio installed.
The noise is really bad in those lines, it's a recording on an old 1983 damaged betamax videotape. -
In MSP If you go into file>project settings>global filters there's many filters that can be applied to the file. You can pick a filter (color correction, denoise come to mind) then pick region to just apply it to the lines that are fudged :P The only trouble is using the right one and finding the correct settings for it, might not work at all but it's worth a shot.
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57 -
removing wind noise
By Reggie6966 in forum AudioReplies: 2Last Post: 31st Aug 2008, 12:47 -
[SOLVED] Removing scrolling lines from videos
By palyons in forum RestorationReplies: 8Last Post: 27th Jan 2008, 23:48 -
Removing ship engines humming noise
By SearchQuality in forum AudioReplies: 15Last Post: 25th Sep 2007, 16:17 -
removing background noise
By pw29010 in forum EditingReplies: 2Last Post: 16th May 2007, 22:27
