I just bought my brand new Plextor PX-712A
But it will not complete one burn.
It start burning but somewere during the burn is gives me the error Burn Process Failed.
I tried many speed rate 8x. 6x 4x
System Info:
Asus mainboard
Intel Chipset
P4 3.2Mhz
1024 DDR PC2700
Burn Software info:
NERO 6.3.02
Media:
Platinum DVD+R 8X
Firmware:
1.05
I got it with 1.03 did not work so I upgrade to 1.05 but still the same.
I have always use Platinum with my Pioneer.
This is the log file from Nreo:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll':
Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 7:18:06 PM
Nero version: 6.3.0.2
Recorder: <PLEXTOR DVDR PX-712A> Version: 1.05 - HA 2 TA 1 -
6.3.0.2
Adapter driver: <atapi> HA 2
Drive buffer : 8192kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <Generic STEALTH DVD >Version: - HA 0 TA 0 -
6.3.0.2
Adapter driver: <St323dk> HA 0
=== Scsi-Device-Map ===
CdRomPeripheral : Generic STEALTH DVD St323dk Port 0 ID 0
DMA: Off
CdRomPeripheral : PLEXTOR DVD-ROM PX-116A3 atapi Port 2 ID 0
DMA: Off
CdRomPeripheral : PLEXTOR DVDR PX-712A atapi Port 2 ID 1
DMA: Off
DiskPeripheral : Maxtor 6Y120M0 atapi Port 3 ID 0
DMA: On
=== CDRom-Device-Map ===
Generic STEALTH DVD L: CDRom2
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1014MB (1039084kB)
Free physical memory: 704MB (721792kB)
Memory in use : 30 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
12.9.2004
UDF/ISO compilation
6:24:36 PM #1 Phase 112 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation started
6:24:36 PM #2 Phase 114 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation completed (no file modified)
6:24:36 PM #3 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
6:24:36 PM #4 Phase 111 File dlgbrnst.cpp, Line 1800
DVD-Video files sorted
6:24:36 PM #5 Text 0 File Reader.cpp, Line 118
Reader running
6:24:36 PM #6 Text 0 File Writer.cpp, Line 124
Writer PLEXTOR DVDR PX-712A running
6:24:36 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
6:24:36 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3882
6:24:36 PM #9 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using DVD media
6:24:36 PM #10 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2286111 (508:01.36, 4465MB)
6:24:36 PM #11 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
6:24:36 PM #12 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: PLEXTOR DVDR PX-712A, Media type: DVD+R
6:24:36 PM #13 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
6:24:36 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2286112 (2286112) = #2286112/508:1.37
relocatable, disc pos for caching/writing not required/required, no
patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length
2286112 blocks [PLEXTOR DVDR PX-712A ]
6:24:36 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [PLEXTOR DVDR PX-712A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0
4681957376, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286112 | lead-out | 1 | 0x00 | 0x41
6:24:36 PM #16 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
6:24:37 PM #17 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
6:24:37 PM #18 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
6:24:37 PM #19 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 4x (5,520 KB/s)
6:24:37 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos,
orig at #0): write at #0
6:24:37 PM #21 SCSI -1066 File Cdrdrv.cpp, Line 1171
SCSI Exec, HA 2, TA 1, LUN 0, buffer 0x02D66000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x24 0x00
6:24:37 PM #22 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 14:17,667 (857667ms) -> OK
6:24:37 PM #23 Text 0 File DVDPlusRW.cpp, Line 564
Start write address at LBA 0
DVD high compatibility mode: Yes
6:24:39 PM #24 Text 0 File Cdrdrv.cpp, Line 1277
18:24:39.250 - PLEXTOR DVDR PX-712A\H2 T1 : Queue again later
6:28:26 PM #25 SCSI -500 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 2, TA 1, LUN 0, buffer 0x03370000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x07 0x02 0x80 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
6:28:26 PM #26 CDR -500 File Writer.cpp, Line 301
SCSI command aborted
6:28:27 PM #27 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
6:28:27 PM #28 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
6:28:27 PM #29 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
6:28:27 PM #30 CDR -600 File WriterStatus.cpp, Line 164
Device not available
6:28:27 PM #31 TRANSFER -24 File WriterStatus.cpp, Line 164
Could not perform end of Disc-at-once
6:28:28 PM #32 Text 0 File dlgbrnst.cpp, Line 1658
6:28:28 PM #33 CDR -600 File WriterStatus.cpp, Line 169
6:28:28 PM #34 TRANSFER -39 File WriterStatus.cpp, Line 169
Could not perform EndSession
6:28:28 PM #35 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 4x (5,520 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912
bytes, created 8/29/2002 1:27:50 AM (Adapter driver for rec)
File 'Drivers\st323dk.sys': Ver=3.23.0.0, size=88736 bytes, created
10/13/2002 8:24:30 PM (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs :
0 (Security Option)
Greets, Mysterio
Moved to DVD Writer forum
Looks like the drive is not operating in DMA mode. This could be the problem.
Steve -
if you have INTEL APPLICATION ACCELERATOR installed that could be the problem. try uninstalling it and use the microsoft drivers instead. similar posts are at the Plextor forum at cdfreaks.com
Thx for al your Replies,
But In Hardware devices the DMA is on also in the BIOS.
It says that device 1 is set to DMA mode 4 and the other is DMA mode 2
Thx for the cdfreaks forum big help over there aswell, but my problem still presist
I have allot of stuff on my HDD and unable to burn them so I can reinstall Windows.Greets, Mysterio
(1) Burn failed !!
By skinney6 in forum DVD RippingReplies: 13Last Post: 4th Feb 2010, 19:01 -
DVDfab failed initializing burn engine
By etlund99 in forum ComputerReplies: 0Last Post: 29th Jul 2009, 14:19 -
Does SVCD2DVD process and burn HD quality DVD from HD .ts file?
By jeemak in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Nov 2008, 23:03 -
New DVD writer... Burn process failed at 2x (2,770 KB/s)
By planetx in forum DVD & Blu-ray WritersReplies: 8Last Post: 8th Feb 2008, 16:40 -
Plextor M402U
By LeFreak in forum Capturing and VCRReplies: 5Last Post: 6th May 2007, 21:33
