hey everyone... I got a little problem. I got a NEC-1300a and I got the Ritek (ridata) dvd-rw. The rewritables are 4x but my burner only says max speed is 1x. My friend has the NEC 2510 which can burn 4x rewritables but only registers at 2x... always half the speed. Can someone tell me if there is a fix for this problem. I appreciate the time and help.
I've had this happen on different occasions, usually on 'bargain' media. I assume the writing software disagrees with the manufacturer as to the quality of the media.
If it works, don't fix it. -
i think on the firmware, they write a specific list of media codes and what those codes are allowed to write at.
so you might want to try upgrading your firmware for your drive, and that might solve your problem.
i don't own the same burner (i have an LG burner) but I know I've had to upgrade the firmware to deal with new discs and such before. -
This site is so big and Im so confused right now after searching for an hour. Can anyone direct me to the right site for my NEC 1300a on a how to upgrade firmware? I really appreciate the help.
Originally Posted by fe519
http://club.cdfreaks.com/forumdisplay.php?s=&forumid=86
If you do a google search.........
A google search brought me to some good sites and now my 1300 has no more locks. It was originally HP 300i with + only. Now it is + and -.It's time to kick some butts, and presto ( if you know what I mean )
Media Player Classic suddenly extremely slow menu
By brucend75 in forum Software PlayingReplies: 6Last Post: 30th Dec 2011, 21:56 -
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 05:07 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 13:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 06:52 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 17:58
