I've got an AIW Radeon for quite awhile, with my audio-out connected to my line-in in my SB card, with the cable provided.
My question is:
Can I do this internally? I know that the SB has plenty of connectors but the AIW... I'm not sure...
Can anyone point me to the pinouts of the AIW internal connectors? (CD In, CD Out and Video I/O Port)
TIA
"Adopt, adapt and improve!"
First, you're assuming there are internal connectors for video etc. There aren't. Not sure about your specific card, but most of them do have an internal audio out pin to connect to the sound card internally.Originally Posted by chicola
If your sound card has an extra internal input then this can free up your external line in. If you don't use 'line in', or if your internal line in ties up the external line in there's no point. Hooking into the CD in should work, and since the players etc normally read in CD's on the bus instead
If you don't have it handy download the manuals for your card from ATI. Should have the internal connection for the audio listed somewhere, mine does.
Alan -
There is a very small internal header on some ATI AIW cards. You can connect it directly to the SoundBlaster internally.
I do this with one of my 9000 Pros. It connects to the 'Aux In' internally from the ATI card. -
Alan,
My AIW manual doesn't detail the internal header.
indo,
Do you have the pinout? Or was it try&error?
I've got an old AIW 7200."Adopt, adapt and improve!" -
USA ones say AUX. PAL ones say goofy stuff, trial and error.
Clean uninstall of ATI AIW 9600
By justin81 in forum Capturing and VCRReplies: 3Last Post: 23rd Dec 2009, 10:41 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 11:56 -
My TV Caps have Low Audio Volume and Hiss - ATI AIW 2006 PCIE
By somebodeez in forum Capturing and VCRReplies: 16Last Post: 26th Apr 2008, 07:08 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 13:25 -
ATI AIW 9800 audio issue
By saggitarius in forum Capturing and VCRReplies: 1Last Post: 27th Jul 2007, 15:17
