urgent help needed.
Im having loads of error messages appearing in both tmpgenc xpress and nero vision
i load avi files into both programs but always getting messages saying invalid file format and other messages.
why is this when ive converted avi files before and had no problems.
or is the actual avi file?
im getting ready to smash the pc up lol
Can you please be a little more specific about the "other messages"? It helps if we know the whole story.
Have you tried the common TMPGEnc Problems thread? Here it is:
https://www.videohelp.com/tmpgenc#problems
This may get you going again.
Cobra -
this is the latest one ive been getting.
This occurs in TMPGEnc xpress mid way through coverting or preparing the file. i got this one at about 50 odd percent.
invalid sample format. (error code 0x80048002) -
Is this a file that you've downloaded or is it one that you captured yourself?
It almost sounds as if there are errors in the original AVI. You might want to run it through VirtualDub and have it check for bad frames. Might not be the answer, but it's one place to start. -
its a file ive downloaded. i will try the program uve listed and let you know what it says
Panasonic DMR-E80H Error messages
By JeffM in forum DVD & Blu-ray RecordersReplies: 38Last Post: 7th Oct 2009, 18:08 -
Pioneer DVR 520H Error Messages
By Sweetow in forum DVD & Blu-ray RecordersReplies: 6Last Post: 16th Jan 2009, 00:18 -
FAVSC Error Messages...in ImgBurn??
By sandman423 in forum Newbie / General discussionsReplies: 3Last Post: 9th Aug 2008, 09:06 -
SV2000 timer error messages
By Mr. Blue Sky in forum DVD & Blu-ray RecordersReplies: 8Last Post: 26th Aug 2007, 08:15 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
