How do I update this drive? Nothing seems to help. I bought dvd's to burn but at 4 speed it fails. It only works on 4 speed. I tried the firmware page but nothing.
Can anyone help me?
Results 1 to 10 of 10
Peace
What disks are you using ?
What firmware version are you running ?
What software are you using to burn with ?
What sort of files are the source files ?
When you say fail what do you mean ? Does the burn not finish ? Do they not play Ok ?Not bothered by small problems...
Spend a night alone with a mosquito -
i would definitely update the burning software that u use. i had this same problem with my dvr-108 drive as well. after i downloaded all the updates from nero, i was able to burn...properly.
When I am burning a dvd at 4x speed it burns untill 30% and then it stops. The programs that i am using finish the dvd and it plays nice on the dvd player but untill 30%. Then it stops (ofcourse).
I have used the latest version of Nero, Dvd decrypter, Instant copy. Nothing seems to burn at 4x speed. I checked out what DVD brand goes best with Pioneer and it was Princo. So I bought that, but still no luck at 4x speed. The files are ISO files and VOB files. I cant tell you the firmware version yet (i am at work) but i tell yopu in the evening.Peace -
Oh dear and where did that piece of info come from....Originally Posted by chipchow
Wouldn't touch them disks with a barge pole.. They may burn OK if lucky but dont expect them to last long.....
I would update nero as well.Not bothered by small problems...
Get some riteks, uninstall nero (its rubbish) get sonic record now max/dx
Well i have had no problems with ritek 4x GO4 printables in my 105.
In my 108 i'm using datawrite 8x fuji dye disks again with no problems.
If you pop into the media forum you will get somemore options.
Prodisk should work OK, not tested any myself....Been more than happy with what i have used.
Not had any issues with nero either use both nero 6 latest ver and 5.10.28 i think with my 105....Not bothered by small problems...
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 06:38 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
Pioneer 106D & Maxell 8x DVD-R
By piano632 in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd Jun 2007, 18:38
