When I capture video in Type YUY2, pretty much uncompressed I can not get the video to play in other software apps. Sometimes if the file is small enough, less than 1GB it will play but not always. As the file gets bigger it definitely will not play. The error message deps on the app. Sometimes it says it is an illegal file and other times it says the file is not accessable.
The audio seems to be ok. If I try to play the file in WM I get the audio only.
I have used Gspot and it can render it using and Unknown VFW video codec. Gspot renders the audio without a problem. Gspot also says that no
codec is nesssary to play the video but it can not render the video unless it uses the VFW video codec.
I have reloaded DirectX 9c and that did not help. What should I do next?
I capture these files using my AIW 7500. I have used the MMC capture software and Virtualdub to capture the files.
Thanks in advance!
wwjd
Results 1 to 1 of 1
What is uncompressed AVI?
By andrewjameshoward in forum Capturing and VCRReplies: 35Last Post: 2nd Nov 2012, 08:56 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 09:20 -
MKV to Uncompressed AVI
By TheLarch in forum Video ConversionReplies: 3Last Post: 15th Apr 2008, 09:11 -
MOV to Uncompressed AVI
By sdiddy in forum MacReplies: 11Last Post: 8th Mar 2008, 10:10 -
.rm to uncompressed avi on OSX?
By midnightraver42 in forum MacReplies: 15Last Post: 10th Nov 2007, 15:01
