  1. Help problems installing TEMPGEnc DVD Author 1.5 or latest .
    When i try to install i keep getting this window pop up ive looked on the net but cant find anything about it can anyone help .
    It starts to install when i click on the install.exe file then this pops up .
    The installation package could not be opened.Verify that the package exists and that you can access it,or contact the application vendor to verify that this is a valid Windows Installer package
    Cheers Kenny
  2. My 2 cents:
    1- I guess your downloaded copy is corrupted.
    2- Or you need a new installer from ms
    It's time to kick some butts, and presto ( if you know what I mean )
  3. Ive downloaded it several times from the officail site and it keeps saying the same .
    What do you mean by a new installer from MS?
