hi all',
I am a newbie here, i would appreciate if someone can help me.
If i have movie clips downloaded fr internet in mpg format and i want to watch it in my vcd player,how do i go about it? thanks.
BTW,i have searched the forum but none has solved my problem,TQ
Results 1 to 30 of 35
Look to the left..'What is VCD'..and the Guides section. In particular, MPG -> VCD guides. The simplest 'newbie' way would probably be through a burn program, ie: Nero -> Create Video CD - hopefully your files are VCD compliant, so no re-encoding is needed - Nero is not the best option in that case. Also, depending on your player, you may be able to burn a normal Data type disc, and open files that way - my chepo Cyberhome CH-DVD-300S does.
[edit] Too slowI'd suggest starting with Nero, and do what the previous poster said [TMPGenc -> Nero] only if a re-encode is needed. I'll probably catch some flak from the anti-Nero people, but its worked just fine for me in most past cases.
Hi All,
I refer to the thread at https://www.videohelp.com/forum/viewtopic.php?t=237145, I did use as instructed to open TMPGENC, and error message "not a supported format". This time I have avi files. Pls adv .Thanks -
Read here?
/Mats -
Hi mats.hogberg,
Thanks a million. You r so HELPFUL!!! I have been searching really high & low just to find the solution. You just showed me the light!!! Thanks. -
You're welcome!
/Mats -
Hi mats.hogberg,
Now i have done creating a mpg file from avi using TMPEGnc. So,can i just use Nero to burn it or need to make further conversion? Pls adv. Thanks. -
You could try to create a VCD from your mpg with Nero, yes, (using the Video CD option)
even if personal expereince with Nero and VCD aren't that good. I prefer VCDEasy to author VCD. VCDEasy is commercial these days, but there is an older free version available that's quite good.
/Mats -
Hi jimmalenko,
Do i have to make any special setting just to view the screenshot? Pls adv. Thanks -
I see the screenshots too...
/Mats -
Hi jimmalenko & mats.hogberg,
U guys r just great! Replied so fast. Anyway,I'll try it again. BTW, I am using broadband. Thanks. -
I have sucessfully created mpg file from avi file. I wouldn't have done it without help fr u guys! Now,I have another problem... How do I multisession the cd burning so that I can continue burning after viewing the old one? BTW, i am using CDR only. Can it be done? Thanks. -
Nope. I don't think that's possible for VCD. Use CD-RW if you don't want to keep your work (but CD-R are cheap!)
/Mats -
I have viewed the coverted mpg movie in my vcd player at home. Now, the movie quality seems to be not satisfactory. It tends to have "pixel" and jerk fr time to time. What has caused this problem? Is it the CDR or how to enchance the quality? Pls adv. Thanks. -
Given a perfect source, pixelation is caused by an insufficient bitrate. You might have to try splitting it over two VCDs to get the quality you desire. Given that they are downloaded clips, I'll bet that the source quality wasn't perfect to start with.
If in doubt, Google it. -
Hi jimmalenko,
you are talking about pixelation is caused by an insufficient bitrate. How do we check the bitrate? BTW,I only have 1 short movie in 1 VCD, i think it is the quality of the CDR, rite? thanks. Pls adv. -
The VCD bit rate has a max limit of 1150 kbps. If you use the VCD template in TMPGEnc, this is what you get. Of course you could try a higher bit rate, but since dedicated VCD players are rather picky when it comes to following standards, it might not work.
As such, VCD is a low spec standard - low bit rate, low resolution, so don't expect miracles. Bad CDR quality mostly shows as complete freezes and serious errors. You could try burning the CD at lowest speed your writer can do. Sometimes that helps.
/Mats -
Hi mats.hogberg,
Thanks for the prompt infomation. Now, everything is ok for conversion fr mpg and avi movie files except wmv. It has NO sound at all. Pls adv. Thanks. -
Never done WMV to VCD (or anything else for that matter) and could only find one guide touching the subject... But you could try looking under other WVM TO ... conversion guides to get some hints.
/Mats -
Hi mats.hogberg,
I have checked thoroughly in the Guides, but nothing relevant to be found.
Yes, someone has mentioned about converting fr wmv to VCD by using TMPGEnc only but didnt say anything about the loss of sound. Can u point me to someone who u think can solve my problem? Thanks. -
Hi mats.hogberg,
I even used the WinAVI Video Converter to convert wmv to avi. I have error message "Information failing,No useable video stream,make sure that media player can play correctly bot hthe video and the audio of the file". But I can play it ok in my window Media Player!!! pls adv. Thank. -
Originally Posted by seanyeap
Putting Together Movie Clips
By SeaBird in forum EditingReplies: 1Last Post: 24th Mar 2012, 11:31 -
need to join mpg clips
By volam1 in forum EditingReplies: 9Last Post: 23rd Nov 2009, 12:21 -
Capturing Movie clips
By Rockwall567 in forum Capturing and VCRReplies: 1Last Post: 30th May 2008, 21:20 -
MPG clips to AVI
By Marcel555 in forum Video ConversionReplies: 2Last Post: 2nd Nov 2007, 17:07 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
