I have a few .ogm files that have dual audio. I want to know how I can encode the avi files (the xvid video of it) with TMPGEnc and use the audio files as different audios for a DVD using DVD-lab.
In other words, I want it to be like a real DVD (where you can change the audio with the DVD Player). I don't know if this is possible.
You can do it with IfoEdit. Once the video and audio files are ready, open IfoEdit. Select DVD Author=>Author new DVD. Add the video in the video section, and the two audio files in the audio section. Burn the authored files. You can change tracks during playback with audio switch on your player's remote.
Hello. -
Found this guide:
https://www.videohelp.com/forum/viewtopic.php?t=222005Blah, blah, blah -
Thanks. I'm going to try them out. I also forgot to mention that there are also subititles in the .ogm files that I would like to keep for the DVD. In case I can't keep the subititles with the tools you told me to use, tell me.
Thanks again
denoise mpeg2 mpg analog video
By jamespoo in forum Capturing and VCRReplies: 7Last Post: 29th Jun 2011, 18:10 -
Add DVB Subtitles to MPEG2 Muxed (mpg) file
By edrin in forum SubtitleReplies: 0Last Post: 26th May 2010, 16:47 -
View\convert\edit *.mpg file (mpeg2) with an Imac
By drastus in forum MacReplies: 3Last Post: 8th Feb 2009, 18:58 -
batch convert .mpg (MPEG2) files?
By shun in forum Video ConversionReplies: 2Last Post: 8th Jan 2009, 09:44 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48
