Hy everyone,
I would know where I can find explained the difference between this two programs (I think DVDx is more easy) and at least which is the best!!!
Results 1 to 9 of 9
Well the difference is that TMPGEnc has better quality and has wayyyy more features than DVDx. I'd go for TMPGEnc if I were you...
I only dream in black & white...
MSN: paschendale@gmail.com -
DVDx is an all in one tool containing ripper and mpeg-encoder. TMTGEnc is an mpeg-encoder which can work with DVDx (using AVISynth plugin) or other rippers (using DVD2AVI). As dhruv said, the quality of TMPGEnc is better than the internal encoder of DVDx. I use DVDx and TMPGEnc in combination.
DVDx has the advantage that it can now use Plugins, so you can use external encoders, I believe you can even frameserve to TMPGEnc, although I dont see the point in using DVDx and external encoder, you might as well use Flask instead, TMPGEnc is best I believe for the main reason you got alot more options to play around with and it's more user friendly.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
DVDx is easy to use (and automatically cuts mpegs into cdr size pieces) but it doesn't syncronize the audio to video. Also VCD quality is not as good as Tmpgenc.
Do you really want it to automaticly cut your movie ? wouldn't that be annoying to find out you spend all that time encoding and then in the middle of an action scene the movie gets cut and then you gotta switch to another CD ?
TMPGEnc is more customizable, and using the Source Range, I can find the best transition spot to split the movie.
Best Regards,
Sefy Levy,
well i suggest you download both(i do)..if i feel layzee and dont care about the quality i use DVDx with a LSX Plugin
but if i care and not that layzee i use TMPGEnc(it a great tool lots of filters and extra stuff to make your video better)
DVDx has a god encoding engine. If it was possible I'd like to use it with frameserving from Premier. I made a few encoding test of the last DVD I made. What can I say, it works fast. Faster than Tmpgenc and the quality isn't so bad. I like it.
HD versus DV
By uno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 10th Mar 2010, 13:24 -
16 x 9 versus other formats...what to do?!
By twersk in forum Video Streaming DownloadingReplies: 3Last Post: 6th Mar 2010, 11:46 -
DV1 versus DV2
By SCDVD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 23rd Feb 2009, 04:18 -
HDMI versus Coax
By SCDVD in forum Newbie / General discussionsReplies: 4Last Post: 24th Nov 2007, 23:26 -
16:9 Versus 4:3
By uno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Sep 2007, 04:35
