i have a movie file in quick time format, when i try to encode it with the tmpegnc it tells me file unsupported or not recognized. how do i fix this problem .
Results 1 to 9 of 9
Make sure you have the QT Movie set as the VFAPI plug in's highest priority, then try again. Remember to reset them when you're done.
Hello. -
which one is the QT movie plug in? and by highest priority does that mean moving it to the top of the list.....and at what number i set it up at.
If you have it loaded, it looks like this:Originally Posted by spiderman03
My plug in is loaded in TMPGEnc's main directory. And yes, it has to be at the top of the list to be the highest priority. The number value assigned to it reallu doesn't matter, as I recall, as long as it is the highest number of all the priorities.Hello. -
i don't have it in my directory , how and where do i get it and how do i load it .
My pleasure. Well, my work here is done...Originally Posted by spiderman03Hello.
when i try to encode the QT file using tmpegnc it freezes the program and my pc, then i got to restart my pc. why would this be happening ? how can i fix it ?
Encoding Question
By ne0natas in forum Video ConversionReplies: 1Last Post: 7th Feb 2011, 21:46 -
I've resolved so much, but still have an encoding question...
By takearushfan in forum AudioReplies: 10Last Post: 9th Jun 2010, 10:25 -
Replacement for TMPEGnc DVD Author for the Mac?
By The Monkees in forum MacReplies: 1Last Post: 24th Feb 2009, 14:36 -
re-encoding question
By Mauserman in forum ffmpegX general discussionReplies: 2Last Post: 17th Feb 2009, 16:42 -
AVI File Not Supported by TMPEGnc?
By The Monkees in forum Video ConversionReplies: 5Last Post: 3rd Feb 2008, 19:26
