I would appreciate any help!
I have a Tape that I am trying to convert from DIX to DVD, first off can any one suggest a free conversion tool....ot a tool with a try and buy period?
I am currently using Powerdirector three Partly because it has a Divx codec, partly, because I allready own it..
I was able to convert the Divx to DVD and then I burned it using Burn at once onto a dvd...the problem was that when I go to watch it on my DVD player I can see the video, but there is no audio...
and now the kicker...If I play the newly converted DVD on my computer it has sound....
any suggestions?
Brad
Try TheFilmMachine. It's an easy way to convert most DIVX or XVID to DVD. Freeware.
If the DIVX has AC3 VBR audio, that may be your problem. Always run the file through AVIcodec or Gspot to see what the file is made of.
Your computer may be able to play the file because it has all the codecs needed, while your standalone player may not be able to use these.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24
