I just finished backing up a movie of mine, and when I tried my final product on two different dvd players, one works, and the other doesn't.
I'm not sure what I did, but i'm confused.
On one dvd player, when the dvd loads it sits at once screen, and I have the option of clicking play right away (to get into the dvd), or it automatically loads itself. It is as if it's skipping a few chapters or something because i hear it.
On the other dvd player, it just stays at the main screen, not loading anything.
I thought I may have SOMEHOW removed the boot command? Is this possible?
If so, how do I re-create it?
Thanks!
Not all dvd players can play the same media. I have 2 dvd players and some media work on one but not the other.
I've tried many other backed up movies and they play just fine on both players (dvd-r).
So something went wrong in the encoding.. could it be the boot process? -
Nothing to do with the encoding unless its totally garbled with no sound or picture,its the authoring part that tells the dvd player how to play the dvd,if you authored properly then it should play on both dvds,if the dvd was poorly burned then one dvd player might play it better than the other.
Originally Posted by X-treme
1090T Computer Won't Load DVD Players
By wulf109 in forum Software PlayingReplies: 7Last Post: 23rd Apr 2012, 13:25 -
[Solved] Backup software recommendations for a dual boot system
By freebird73717 in forum ComputerReplies: 3Last Post: 17th Nov 2009, 14:19 -
XP won't boot!
By seven_deuce offsuit in forum ComputerReplies: 12Last Post: 6th Dec 2008, 10:26 -
pc won't boot
By Dadsgrice in forum ComputerReplies: 12Last Post: 11th Jul 2008, 12:34 -
External Comstar DVD/CD Burner won't boot up but fan still turns on
By smiles in forum DVD & Blu-ray WritersReplies: 11Last Post: 3rd Oct 2007, 09:05
