Some of my PC friends have been bragging about a programme called CCE which apparently gives superior quality when backing up dvd to dvdr. Now, I've always extolled the virtues of the Mac, especially in video quality, so, I'm curious. Has anybody done any comparisons? Is there a quality difference say, using CCE and DVD2OneX? And if there is, does anyone know if CCE would work with VPC?
MJ
all the better - more common encoders - are for pc ..
cleaner is not that good for example and bitvice is still the best quality software encoder for the mac (that i have seen) .. ... there are some VERY good hardware encoders for mac though, many costing thousands of bucks .. but the canopus dvd maker mpeg2 hardware encoder is is good for the mac ..
i expect some others to be ported soon for osx ....
cce can cost between 60-2000$ though ... be aware of this..
see the mac vs. pc encoder shootout here http://videosystems.primediabusiness.com/ar/video_mpeg_encoder_shootout/"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
For compressing DVD to DVD-R DVDRemaster gives you much better quality than DVD2OneX. The only downside is that at its best quality setting in which it completely re-compresses the video is quite slow taking up to 8 hours to do a whole DVD (8GB) using a G5 1.8DP but the results are very, very good.
If you were to run it in VPC it would be the slowest thing next to Windows booting up. It's not worth it.Originally Posted by MJYM
#Originally Posted by londor
Hi Londor, while this may be true with some DVDs, it seems not to be for others. It was only with the one disc (a 4 episode, 3 hour, Deep Space Nine disc) but earlier this year I personally compared the results of DVD2OneX 1.3 and DVDRemaster 1.2.x and found that DVD2OneX's 'variable mode' results were almost indistinguishable from the best-quality (slowest) DVDRemaster results. The only difference was the DVDRemaster might have been slightly better in dark scenes, but it put loads of glitches into the menus (green blocks etc). (DVDRemaster's quick mode was noticeably worse than dvd2onex) -
I have the latest version of both programs DVD2OneX 1.4.1 and DVDRemaster 1.4. I use DVD2Onex for "movie only" back-ups using the variable mode and it works pretty well and is fast but when the movie is very long (over 2 hours) or you want to back up the whole DVD it does not render the same quality as the M2VDownsizer recompression module of DVDRemaster at its best setting with which you can get 8GB down to 4.3GB without almost any noticeable loss in quality. Also I have never experienced any glitches using DVDRemaster.
Glad to hear it works so well for youOriginally Posted by londor
Unfortunately it most definitely didn't do it for me. Presumably DVDRemaster 1.5 is better than 1.2.x used to be, I don't know since I'm a happy user of dvd2oneX (like most other people on this forum
) Sometime soon though - I promise I will give DVDRemaster a 2nd chance.
PS nice to see some of the old afterdawn crowd over here
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 05:04 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 05:45 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
im new to mac... is there a mac program that does what tmpgenc dvd author 4
By ochsfamily in forum MacReplies: 0Last Post: 12th Dec 2009, 22:13
