Using DVD Decrypter and DVD Shrink to Backup Any DVD by steptoe
Am I doing something wrong? Or did Steptoe forget to mention the 4 hour encoding process? I followed the guide step by step.. First Decrypter was used to rip, then shrink to backup....Shrink loads up the movie files extremely quick. I set everything to "automatic" compression. After about 2 hours elapsed and Dvd Shrink completed analysing/transcoding, I'm not sure the lingo. I was counting down to completion with lots elation thinking it's time for burning, but then it goes into this "encoding" process that is excruciatingly slow, as I write, the countdown is at 3 and half hours to go. Is this process necessary? Am I doing something wrong? Please advise.
It`s about right, depending on your computer speed. I usally set it up before i go to bed then that way it doesn`t seem that duantingly long
Without knowing your computer specs, it is very hard to give you an honest answer. I know with my machine, the DVDShrink process takes anywhere up to about an hour if I do Deep Analysis and have the AEC options checked. You could try unchecking the AEC options and only do Deep Analysis if compression is less than 85% and still get excellent results IMO in much less time.
If in doubt, Google it.
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
Looking for guide: TV Episodes to DVD!
By munchgrunch in forum Video ConversionReplies: 3Last Post: 15th Jul 2008, 23:19 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 20:03 -
DVD Author Guide
By brvignesh in forum Authoring (DVD)Replies: 1Last Post: 11th Dec 2007, 08:39 -
DVD Rip Guide
By brvignesh in forum DVD RippingReplies: 11Last Post: 5th Dec 2007, 08:18
