  1. How many hours of tape do you shoot between cleanings?
    I've got a JVC with about 15 hours on it and has never been cleaned.
  2. Digital Device User Ron B's Avatar
    Mar 2003
    The Gorge
    Hello-I don't clean mine until I see some image degradation, usually something like "snow". Since I'm using an abrasive cleaning cassette(the wet cleaning ones set off the camera's moisture sensor), I like to keep cleanings to a minimum. You should get at least 200 hours from a set of recording heads.
    When I start to see a problem.
    Nov 2003
    Charlottesville, VA
    Both Sony and Panasonic recommend cleaning heads around 50 hours of use.
  5. Member mikesbytes's Avatar
    Sydney, Australia
    I have never cleaned the heads on my Pansonic camera. They have never got dirty, why, I don't know.
    Id recommend only cleaning them, when you have a visable probem, as the head cleaners are a litltle hard on the heads.
  6. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    On my Sony, I clean it once every 20 hours of recorded footage or like Lordsmurf said, When I see a problem.
  7. SO you guys use an abrasive cleaning cassette.
    I just got a 1987 Panny Sat. and although it seems to work well I could see a large difference in quality between recording to tape or direct to the ATI AIW with the line out (which avoided the tape altogether)
    overloaded_ide
    Spambot FOOD
    Anti-Spam
