Every time i try 2 convert certain divx movies to mpeg-i convert with no sound. I have tried 2 extract the sound into a wav file-then convert the video adn soudn seperate.This is done using Virtual Dub.I have a list here:
http://www.divxmovies.com/list.php?handle=mr_rastaman
Can sombody help us out-a real pain in the ass
cheers in advance
mr_rastaman
when you convert the audio to wav with virtualdub are you sure that you have select audio->full processing? the wav file should be about 10 MB/minute.
Baldrick,
Just to clarify, the 10MB per minute will vary depending on the avi's source audio.
You're not suggesting to have VirtualDub do resampling
There are a couple of better resamplers - SSRC, SCMPx - off the top of my head. The important thing is to have VirtualDub convert to PCM.
Just my $0.02,
G
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 05:07 -
network cat5 guys....
By rubberman in forum ComputerReplies: 7Last Post: 3rd Apr 2008, 11:59 -
Can you guys look at my commercial?
By dogmaratt in forum Off topicReplies: 10Last Post: 17th Feb 2008, 10:42 -
Ok Guys, I need some advice on AVI?
By Soccerman77 in forum Video ConversionReplies: 5Last Post: 25th Nov 2007, 23:39 -
Wow I found you guys
By alanr in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 15:27
