Since I don't have a DVD burner, I'll be burning my video on a Mac (using XP Home). But I need some help:
- will there be any compatibility issues bringing over the ISO and mpg2 video?
- the file is 1.78 GB. What program should I use to split it into 700 MB segments? Do Macs recognize rars?
- I will also be burning a DVD with the ISO and video on it, totalling 3.56 GB. Should I do anything before it?
If it helps, I think the burning apps I'll be using are "DVD Studio Pro" and "Toast".
Thx!
Toast and DiskCopy can handle iso's just fine. Rar's also work in Mac, I like using MacParDeluxe, but others use Gumby or UnRarX or even stuffit. Is the iso already authored? If so you will need to extract some files to bring them into DVD Studio Pro. Otherwise simply burning the iso (once whole again) as a disc image in Toast works too.
Transfering video (Canon VixiaHF100) to a Mac (10.6 - snow leopard)
By JKennedy in forum Newbie / General discussionsReplies: 1Last Post: 7th Sep 2009, 23:28 -
How to Burn an ISO on the Mac
By Jeff_NJ in forum MacReplies: 6Last Post: 19th Nov 2008, 10:11 -
ISO extractor for Mac
By flvgordon in forum MacReplies: 3Last Post: 9th May 2008, 03:28 -
How to burn a ISO file on a Mac? Can this be done?
By babybreese in forum MacReplies: 9Last Post: 30th Aug 2007, 21:45 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
