hi guys.....
i reencode alot of pal svcds to ntsc dvd with no problem.....but occasionally i get one that no matter what i do i cant get the sync right....on these occasions i have tried both reencoding with just the TMPGenc template provided...and splitting the file to work on both with besweet.gui and AVI2DVD...
this process has worked for me many times and i am doing nothing different on these occasions....is there any way i can check the mpg and repair any problems that might cause it?
looter
Results 1 to 12 of 12
The best way to check is watch the video,if you've done this lots of times then you should have noticed any mistakes by now.
ive been using this guide
Converting SVCD PAL 25fps to NTSC 23.976 fps
https://www.videohelp.com/forum/viewtopic.php?p=1038208#1038208
this is what my besweet setup looks like
the only thing i see is different is the downconvert sample rate isnt checked..i have also tried checking it and it still doesnt sync
as far as using tmpg to reencode the video.....ive been following the steps excact
anyone?
looter -
img didnt take....try again
if this dont work take my word for it...i give up
What I woudl try is to reencode the video in the same format that it is in; i.e. SVCD NTSC => SVCD NTSC
I have tried this in the past and it has worked out.
-Machine -
thanx machine
it worked on the first one thanx for the help and thanx for the great guide .......it seems like most of my bad files are from the same source......wonder shat it could be?..i heard something about time stamps on the audio and video or some such shit being off
thanx again for replying guys
looter -
The problem is like this..
If the NTSC to PAL conversion (originally) was done poorly (or boarderline, to
that point that you don't notice it or much) then you're chances are negative.
Once you start speeding things up or slowing things down, and/or changing
the FPS to another number and/or in combination w/ audio, reversing this
whole process can sometimes be forgotten (if done poorly, as most likely in
your case)
At best, you'll probably get close, but never hit that high note.
Good luck,
-vhelp -
seems to have worked......thanx machine...fixed a few of em
doesnt fix em all though......for some reson a check with avicodec doesnt recognize the audio file.....just registers a blank line.....i have the right codecs installed and it plays fine....
wonder why
looter
vhelp...
im doing the first conversions the source file is is from a pal region -
i finally figured out the problem....the template for svcd ntsc film(23.97fps)....wont work sometimes for the audio....if i use the svcd ntsc 29.97fps it works out ok....
does anyone know how i can prevent any future mistakes....23.97 cuts 2 hours of reencoding for me(if it works)
looter -
------UPDATE-----
using tmpgenc to create an identical file to work with helps occasionally but doesnt always work.....its time consuming and frustrating .....it seems to be one specific source that gives me most of the problems....i cant do anything about avoiding that source.....again.....i noticed the audio and video are runnig at different frame ratesafter encoding.....the gaps in the sync are longer at the end of the files.....also i get alot of stuck frames even after using vcdgear to fix the mpgs
are there any other programs out there to edit mpgs?.....im tired of using tmpgenc
looter -
machine.....
thanx for the guide and the help after....it turns out that i gave up....i figured a new way to convert in real time.....i have an apex dvd player with an internal converter....i just bought a capture card and sent the movie through it.....it converted instantaniously and only took as long as the movie lasted......1.5 hours....cant beat that.....even editing is easier with the software included.....cap wiz
thanx again
looter
Audio Sync Problems
By Blue_3 in forum AudioReplies: 5Last Post: 10th Apr 2008, 18:17 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 12:03 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22 -
I've got audio sync problems (too)
By gigantibyte in forum EditingReplies: 26Last Post: 10th Jun 2007, 10:17 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 20:42
