Hi
if I want to burn a low quality video that i find on the internet (divX file) on a DVD-VCD
What format shoud I convert the file into ?
If you want to make a VCD, it'll have to be a VCD-compliant MPEG-1.
Thank you for your reply
So I need to convert it the same way I do for VCD ?
and then after only use these file to burn my dvd-vcd ? -
If you are burning a DVD it has to be DVD compliant. VCD format (352 X 240 mpg1 1130 kbs, I think) is acceptable for DVD but the audio has to be 48 instead of 44 whatevers (sorry I'm not good with details).
Low File Size yet retains the original quality. How?
By NeroLi8gerzid in forum Video ConversionReplies: 8Last Post: 6th Oct 2011, 18:46 -
What do you think??? Maximum Quality/Low File Size DVD conversion
By iqbal88 in forum DVD RippingReplies: 6Last Post: 7th Aug 2011, 03:48 -
Best Video Format/Codec For Small Size, Yet Low Loss In Quality?
By kiwisoup in forum Video ConversionReplies: 13Last Post: 27th Jul 2010, 11:01 -
Auto-GK file output, low quality despite large size
By Fallout1 in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2009, 19:27 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18
