  1. Hi everybody,
    I have 2 movies, one in RMVB and the other one is QuickTime.
    Is there any way to convert them into XviD AVIs?
  2. allright thanx, i found something somewhere else
    "That's me in the corner, that's me in the spotlight, losing my religion"
    eo video...and you can click on the tools list and select MOV to AVI and RM to AVI for more tools.
  4. hi Blackrick,
    thanks alot for your time, It worked!
  5. It worked, but it loses the synch between audio and video track, any solution anybody?
    how can I find out what's the frame rate of a MOV video?
    Australia
    Quicktime will tell you what the frame rate is.
    While it's playing select 'Window' -> 'Show Movie Info' or just press [Ctrl][I] to bring up the info window.
  7. thnx I'll try it right away
  8. I really hate to stretch this topic but it didn't work, and i have no other way, i even used a software named cleaner 5 which didn't do anything at all!.
    the movie's frame rate is 25, but still when I converted it, there's no synch, I even used interleave in VirtualDubMod to fix it. it's good at the beginning but loses its synch as i go forward. It shouldn't be encoding video by the right frame rate or something.
