Hi
I want to change height & weight of my movie plus cutting the black edges. with VirtualDubMod 1.5.1 it takes a few hours to do that. is there any other software that does it faster?
Results 1 to 15 of 15
Check out frameserving - it could speed things
up for you depending on your source media and
what you want to export.
As you did not elaborate on media source to
export source I can't say for sure. -
Hi
my movie is in XviD, and i want to save it as XviD without losing any quality. I just want to remove the black edges and maybe change the height/weight of the movie.
what's is frameserving? where is it and what does it do? -
Mission impossible. If you remove edges etc. you will have to re-encode your video file. XVid is not a lossless codec, so your border-removed avi will have a quality loss over the original one ... unless you save your avi using huffuv codec, but then the size of your borderless avi will be tens of gigabytes.Originally Posted by ramin
Encoding a full lenght movie is not a small task for your processor, a few years back we were still talking of days of encoding time, not just a few hours.
What is the purpose of re-encoding the movie. Why do you want to remove borders / resize? -
Hi you all, thanks for responding
When I ripped this movie from DVD, i didn't change the resolution
so now the picture is squeezed! and impossible to watch before changing the aspect ratio using FFDshow filter. so now i want to remove the black borders and change the resolution to something like 640x300. (the picture now is 720x480 include black edges)
and Tommyknocket, thanks for the link but I think that'll take more time, and still TMPGEnc changes the avi to mpg. -
The video from the DVD is stil in it's anamorphic format. Perhaps a media player with the capability to alter the aspect ratio during playback?
I have used the DivX player with AVI files and it allows you to select an aspect ratio. Perhaps this is all you need.The more I learn, the more I come to realize how little it is I know. -
To get rid of the borders (and avoid re-encoding) why not use the NULL TRANSFORM filter in VirtualDub?
This will allowing the CROPPING button to become active (so you can crop out the nasty balck bars etc) and let you do a DIRECT STEAM COPY (for both video and audio) thus creating a new file (less the borders) without re-encoding....just save the AVI under a new name...it wont sort out the AR though.
Also I find ZOOMPLAYER invaluable for playing avi's (especially to correct encoding AR problems). -
I'm using ViPlay which can change the aspect ratio and the resulotion, also with FFdshow i can do that, no problem there.
Null Transorm does it, ok, but then I have to re-encode the video which makes the video size bigger, or if not, makes it with a less quality.
But how do I get rid of the black edges in the movie without losing quality?
that's the whole question!. -
My mistake, you are indeed correct, you need to use FP mode to use the cropping function in VD.
In order to remove the black borders, you need to crop the video frame from it's top and bottom parts. In order to do that you need an editor (like VirtualDUB) that will decompress the video file, perform the crop and then re-compress the video with the codec of your choice.Originally Posted by ramin
You always lose something on every compression phase, unless you use a lossless codec (huge file). You can get away with most of this loss even if you use the same codec, by applying the same or higher bitrate during encoding.
Open the file with VirtualDUB and check in File Information about the codec and the average bitrate. Apply the crop filter and then save using the same codec and the same average bitrate as well as frequency of key frames.
Since you will be cropping the letterbox black borders, you will be reducing the frame size and the bitrate requirements, which means your new file will have a better chance to encode at the same quality and the same bitrate as before.The more I learn, the more I come to realize how little it is I know. -
Hey SaSi,
that's a really interesting way
. part of my problem was that I didn't know what bitrate i used before. THanks alottt, that'll help alot
let's just see what results do I get
Codecs gone, not showing up in VirtualDub or other software....
By ggouweloos in forum Video ConversionReplies: 19Last Post: 15th Sep 2012, 00:24 -
Virtualdub filters in avisynth-faster? How to use them?
By salidarius in forum EditingReplies: 10Last Post: 3rd Mar 2011, 22:13 -
Help with virtualdub, or software suggestions
By chunlix in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2010, 13:28 -
Req: Software For A Faster Pc Start
By Teac23 in forum ComputerReplies: 8Last Post: 14th Jan 2009, 10:46 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 23:21
