I decrypted a commercial DVD (that was not copyrighted or protected) and expected VOB files, IFO and BUP files. Instead I got VTS_1_01, VTS_01_2, etc. I did get BUP files. How do I convert these into VOB files?
Those should be .VOB files. I'm guessing that they're about 1Gb in size?
Just make sure you uncheck the "Hide extensions for known file types" and any other similar options.
It's time to kick some butts, and presto ( if you know what I mean ) -
Yes they are 1, 048,544 KB, so that is a gig right? So anytime I see the form of VTS_01 that would probably be identical to a VOB file? I wonder why it just wouldn't say VOB? I wonder if a video editing program will treat it in all respects as a VOB?
ditto this...Originally Posted by US Guyjust a thought
mastersmurfie -
where would that be located?
in settings, internet options, someplace?
or start, run ? -
under control panel->folder options->view...
just a thought
mastersmurfie -
thanks for all the help
it is going one way, from others to me
if anyone needs some help with excell or tradestation 8 maybe I could help someone back
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
authoring PAL DVD using "mpeg-4 avc" NTSC 1280x720 VOB files
By ah76 in forum Authoring (Blu-ray)Replies: 14Last Post: 31st Oct 2009, 10:31 -
The "convert a single VOB file to a DVD" project!! :)
By djdust in forum Authoring (DVD)Replies: 42Last Post: 23rd Feb 2008, 08:49 -
Using VOB files for a "composite" DVD.
By larynx in forum Newbie / General discussionsReplies: 1Last Post: 21st Oct 2007, 14:43
