  1. Hi
    sorry I could not find the right forum for this question.
    I got a new DVD Recorder last week, type:
    <_NEC DVD_RW ND-2510A> Version: 2.05 - HA 2
    I have a new version of Nero Express installed:
    Nero version: 6.3.1.20
    I can burn DVD+R discs without problems but I when I try to burn DVD-R discs I get a command sequence error! The recorder should burn both types.
    Can anyone help me with this problem?
    For more information see the error log from Nero included below.
    Regards,
    KristĂ*n
    --Error Log--
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 7.12.2000 12:00:00
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 22.7.2004 17:33:44
    Nero version: 6.3.1.20 (Nero Express)
    Recorder: <_NEC DVD_RW ND-2510A> Version: 2.05 - HA 2 TA 0 - 6.3.1.20
    Adapter driver: <> HA 2
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ?
    CD-ROM: <HL-DT-ST RW/DVD GCC-4160N>Version: 0013 - HA 1 TA 0 - 6.3.1.20
    20:56:07 #12 Text 0 File ThreadedTransferInterface.cpp, Line 984
    Prepare recorder [_NEC DVD_RW ND-2510A ] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1386184704, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    0 | lead-in | 0 | 0x00 | 0x41
    0 | 1 | 0 | 0x00 | 0x41
    0 | 1 | 1 | 0x00 | 0x41
    676848 | lead-out | 1 | 0x00 | 0x41
    20:56:07 #13 Phase 24 File dlgbrnst.cpp, Line 1855
    Caching of files started
    20:56:08 #14 Text 0 File Burncd.cpp, Line 4183
    Cache writing successful.
    20:56:08 #15 Phase 25 File dlgbrnst.cpp, Line 1855
    Caching of files completed
    20:56:08 #16 Phase 36 File dlgbrnst.cpp, Line 1855
    Burn process started at 2x (2.770 KB/s)
    20:56:08 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2344
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    20:56:08 #18 Text 0 File dlgbrnst.cpp, Line 1713
    Set remaining time: 8:53,623 (533623ms) -> OK
    20:56:08 #19 Text 0 File DVDR.cpp, Line 1942
    Recording mode: Sequential Recording Mode
    20:56:08 #20 Text 0 File Mmc.cpp, Line 20531
    Set BUFE: supported -> ON
    20:56:08 #21 Text 0 File DVDR.cpp, Line 2083
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    20:56:08 #22 Text 0 File Cdrdrv.cpp, Line 8128
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 5
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26127F h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Start sector number of the current Border-Out: 2FE10 h
    Start sector number of the next Border-In: 2FFA0 h
    Media Specific [16..63]:
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
    20:56:08 #23 Text 0 File DVDR.cpp, Line 5367
    Booktype counter: 499, Booktype selected in EEPROM, command version 1
    20:56:08 #24 Text 0 File DVDR.cpp, Line 5367
    20:56:26 #25 Text 0 File DVDR.cpp, Line 4661
    Drive: _NEC DVD_RW ND-2510A
    Booktype request: DVD-ROM, write to EEPROM
    Changing the book type was finished with error code: 0
    20:56:29 #26 SCSI -1023 File Cdrdrv.cpp, Line 1442
    SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x0A5C0000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x2C
    Sense Qual: 0x00
    CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0B
    0x00 0x00 0x00 0x00 0x2C 0x00
    20:56:29 #27 CDR -1023 File Writer.cpp, Line 304
    Command sequence error
    20:56:29 #28 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
    20:56:30 #29 Text 0 File ThreadedTransfer.cpp, Line 223
    conversion idle, stopping reader
    20:56:30 #30 Text 0 File DVDR.cpp, Line 2325
    EndDAO: Last written address was -1
    20:56:30 #31 Text 0 File DVDR.cpp, Line 5367
    20:56:30 #32 Text 0 File DVDR.cpp, Line 4661
    20:56:30 #33 Text 0 File dlgbrnst.cpp, Line 1713
    Set remaining time: 0:00,000 (0ms) -> OK
    20:56:30 #34 Text 0 File dlgbrnst.cpp, Line 1713
    20:56:30 #35 Phase 38 File dlgbrnst.cpp, Line 1855
    Burn process failed at 2x (2.770 KB/s)
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    I've seen a lot of posts lately about nero. Have you updated it, I think there's a patch to resolve issues with the SP2 update.
  3. Hi
    yes I updated it last week because the older version didn't seem do recognize -R discs and just spit them out. After the update, it accepts the -R discs but cant burn them.
    KristĂ*n
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    And the firmware for your burner? Sorry I probably should have mentioned that before. Carefully read the following information from thios link. Twice if possible Find out as much as possible before installing..... I can't find much on the nec website but research it thoroughly.
    http://www.cdrinfo.com/Forum/printable.asp?m=73532
