I downloaded a cartoon divx file for my daughter but the audio id terribly out of sync. I mean around 3-5 seconds behind the video.....
Is there a good software that can help me fix the problem?
thanks!
sp
Use Virtualdub. Under audio>interleaving>audio skew correction. You can use + or - amounts to correct it and test it by playing the file in the main window. Set the audio and the video to direct stream copy and save avi when you're done.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
DV Type-1 to Divx video/audio sync problem.
By cgmarsh in forum Video ConversionReplies: 0Last Post: 10th Aug 2010, 16:35 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 22:18 -
Audio track out-of-sync with DivX/XviD media file after video was split
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2008, 04:30 -
MPEG to Divx audio sync problem
By starless in forum ffmpegX general discussionReplies: 8Last Post: 11th Oct 2007, 05:38
