I'm having two problems, and one lead to the other.
I've been adding subtitles to some DVDs and using DVDMaestro for the authoring. The first problem is on one movie, when I try to import the video .m2v asset in Meastro, I get this error "Temporal references in GOP #21 (Zero-Based) are out of sequence" I've been searching the forums and many others have had the same error, but I have found no solutions.
So, I used ReJig and IFOEdit (I tried both) to Author the movie and used SRT2SUP for the processing of the Subtitles. The resulting DVD when played on my stand alone DVD player shows the subtitles shaking a bit. When I use Maestro, the subtitles look perfect.
I really would like to get around this "temporal reference" error and be able to import the .m2v file into Maestro and continue to use it.
But if I could fix the shaking subtitles using ReJig that would be great also.
Any suggestions on either front.
Results 1 to 1 of 1
temporal degrain
By unclescoob in forum RestorationReplies: 10Last Post: 3rd Mar 2012, 22:53 -
FAVC Error: Reference to non-existant scene
By major4579 in forum Authoring (DVD)Replies: 4Last Post: 7th Jan 2012, 08:33 -
Proc Amp Color Reference
By Cingular in forum RestorationReplies: 2Last Post: 3rd Nov 2009, 15:31 -
reference Windows Media Encoder library error
By George2 in forum Newbie / General discussionsReplies: 0Last Post: 15th May 2009, 05:44 -
VirtualDub & VirtualDubMod Error Messages..R & R
By sandman423 in forum EditingReplies: 4Last Post: 18th Oct 2007, 05:30
