I had a harddrive crash a few days age and i installed all new versions of the software i use smart ripper ver. 2.38 then use dvd2avi ver. 1.76 and finally tmpgenc ver. 2.01 and for the cdr program i use nero 5.0 everything works fine untill i actually go and watch the movie in my dvd player on sceens where they pan the whole screen it seems to skip in the mocie it is really noticable.
I have used the forced film option in dvd2avi so i know to use the film template in tmpgenc but that does not even work i am really going crazy over this. I used to be able to burn a movie at 480X480 in svcd format but all the new movies(13 days, swoedfish and Shrek)i can only do in vcd format with accetable quality. If anyone has ripped any of these movies in svcd format can u please tell me the software u used and how u did it step by step. thank u for your time
forced film only works on telecined sources that are close to 100% film(press f5 in dvd2avi to preview). in contrast hard-telecined films will be reported close to 100% ntsc & forced film will hopelessly fail on this type of source. if this is indeed the root of your problem you need to turn off forced film, load ntscfilm template, specify interlaced source, select correct field-order(critical), enable inverse-telecine filter
well i used forced film and it came out wat better with no image varations in the movie thanks for the help
read the guide on my homepage....it covers nearly all types of ntsc sources. that is unless you have a specific question to ask?
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Confused about 1080p
By gauche in forum Newbie / General discussionsReplies: 4Last Post: 18th Jan 2009, 09:51 -
Still confused on upconverting
By glp103 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2008, 17:42 -
resizing, I'm confused!!!
By nalooti in forum Video ConversionReplies: 5Last Post: 19th Nov 2007, 09:14
