I am using VirtualDub 1.5.10 and the Divx codec 5.1.1
I am having trouble converting a file to a new bitrate (in hopes of reducing its size). I'm not looking for anything major -- just like (for example) 90-100 minutes of 320x240 on one 80-minute disc. Even if I set ridiculously low bitrates, the resulting file is only slightly smaller. All the tutorials that I could find on here are for earlier versions of the codec, and so the configuration screens that I have look nothing like the tutorial, and I can't seem to "map" the changes over. Not even sure what to ask beyond this.
HELP!!!!!!!!!
Well, many DivX's I've seen are like 640x350, 120 min+, and look OK, so it's not impossible. What's your source (audio bitrate/codec, video bit rate codec)?
/Mats -
Usual source is from a capture card:
Video - 352x240 - 768 kbps (DivX 5.1.1)
Audio - Mono WAV file (haven't been able to get audio compression working)
Generates a file that is about 665 MB for an hour of video. I'd just as soon leave these settings alone and then convert as need be. The conversion is what I am having trouble with. -
OK, let me count: 90 minutes, 768 kbps gets me to around 520 MB. That's video. But a wav file takes an amazing amount of space! Encode it to MP3 or something at 128 kbps, and you'll end with 520+86 MB - Well within the "one CD" range... It's the wav audio that's filling up your file - not the video.
/Mats -
Duh -- silly me -- I bet you are right. I will test this later today.
Thanks for showing me the forest around the trees.
Glad you fixed it!
/Mats
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Finding out the peak bitrate of a DivX file
By Anakin in forum Video ConversionReplies: 2Last Post: 8th Oct 2011, 16:25 -
divx to avi with divx author
By pred in forum Video ConversionReplies: 4Last Post: 12th Nov 2008, 23:32 -
Divx 6.8: bitrate vs target quantizer?
By peggypwr1 in forum Video ConversionReplies: 1Last Post: 5th Feb 2008, 22:35 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 13:28
